Effects controlled by autio in - how to get this to work?
Sotaru
Unread post by Sotaru » 05 Sep 2011, 18:10
I tried Usine yesterday and I really like it. Unortunately I did not
Effects controlled by audio in to work what I need, so I am unsure...
Setup:
Scratching Turntable and Mixer -> PC Usine -> Audio Out
I want to add effects that are controlled by the start of the audio input, i.e. audio in triggers
an envelope (or sequencer or whatever), which controls some effect parameters.
I tried using an envelope module and it creates control data, but the knob on the vst (Trasher2)
always stays on the same position.
I went through all the tutorials, but I don't get it, how this is done.
Can anybody give me a pointer to a solution?
Thanks!
Sotaru
Unread post by nay-seven » 05 Sep 2011, 19:00
hello and welcome
have you try the sub-patches audio to midi ( and use the frequency/1000 ) for example..?
there's also the beat follower if you want trigger events..?
Sotaru
Unread post by Sotaru » 05 Sep 2011, 20:22
hi,
I tried the beat folloower. It seems to work.
thank you.
regards
Sotaru
