New sript issue
Ken29
Unread post by Ken29 » 30 Aug 2011, 23:00
I guys,
I'm trying to get better in the art of scripting. I have this problem I do not understand...
On this simple patch, when the "switch" change from 0 to 1, "data out" change from 0 to 1 but not the Toggle... Here's the script. Thanks
// Changement de nom
// parameters declaration
Var InA : tParameter;
Var OutA : tParameter;
procedure init;
begin
InA := Createparam('Entrée', ptSwitch);
SetIsOutput(InA, False);
OutA := Createparam('Sortie', PtButton);
SetIsInput(OutA, False);
end;
// main proc
Procedure Process;
begin
If Getvalue (InA)= 1 then SetValue (OutA,1);
If Getvalue (InA)= 0 then SetValue (OutA,0);
end;
Unread post by nay-seven » 30 Aug 2011, 23:38
it's not a script issue, add a switch to a toggle module and you'll have the same result..
as the toggle module receive 1, he toggle..
and as long as it receives a 1 he will toggle
Ken29
Unread post by Ken29 » 31 Aug 2011, 13:16
You're right, I've just add a switch to a toggle and tried. When the switch goes to 1, toggle out should be 1, then the switch goes to 0 and then to 1 again, the toggle out should be 0. But it doesn't work and I don't understand why.
Kenan
Unread post by nay-seven » 31 Aug 2011, 13:44
try to create a wire from the inlet of the toggle button, you'll see that Usine propose you a button not a switch
the toggle module work this way, each time he receive an impulsion (like button) he toggle, this mean he change the value
if you use a switch with a fixed value your force the module to always toggle..?
Ken29
Unread post by Ken29 » 31 Aug 2011, 18:22
Ok, I changed my script like this and it works now... Thanks
// Test
procedure init;
begin
InA := Createparam('Entrée', ptButton);
end;
// main proc
Procedure Process;
begin
end;
Users browsing this forum: Google [Bot] and 24 guests
