controlling renoise via osc in usine?is there a small tutorial somewhe
ErotiCore SteNch
i need to make a small "controller"for controlling simpel controls in renoise via OSC in usine
something i need to control is the /renoise/transport/start
and the //renoise/transport/stop
and some other smaller things,i looked around but i really cant get my head around how i connect usine to renoise via OSC so i can control renoise parameters in usine
can anyone give some hints or if theres a small tutorial somewhere that shows how to set this up?
First you can read this tip :
Using OSC
then i suppose you have to refer to Renoise manual to set receive port and address
have you yet work with OSC or..?
Using OSC
ErotiCore SteNch
must admit im a newb in the OSC world
ok, gone to check
ErotiCore SteNch
this is like greek to me,:)
not easy
I've test quickly
using the message give in the renoise manual
here for example to send note one
/renoise/trigger/note_on(number, number, number, number)
Trigger a Note-On.
arg#1: instrument (-1 for the currently selected one)
arg#2: track (-1 for the current one)
arg#3: note value (0-119)
arg#4: velocity (0-127)
but I've always a message like this in renoise OSC console
/trigger/note_on/ with 4 arguments (REJECTED)
maybe you have to ask on renoise forum or maybe there's some renoise users here
I've test quickly
Trigger a Note-On.
ErotiCore SteNch
hi nay-seven
thanks for your efforts,yeah i also kept getting those REJECTED messages
i have posted on the renoise forum and linked to this topic hopefully they can look into it
ok
i've also test in integer or array mode , same results...
also test without the last / in the address
so I've this message
/trigger/note_on with 4 arguments
so no more rejected but no results too...
ok, so first result
I've use a fresh empty song in renoise and double click on a sample
in usine I've use a trunc module on parameters 3 ( note number )
and Renoise react
and Renoise react
ErotiCore SteNch
thats good news i got this responds on the renoise forum
will test some more tommorow its bedtime soon
Can you link this thread back to the admin so he can post here? Is the replier the developer?
OSC works with dozens of other configs and controllers that I know of. I can't test Usine because I'm on OSX and there doesn't appear to be a Mac version. Here's a python example. Here's the code that does note_on in that package.
OSC is a standard like HTML is a standard. It takes a lot of fiddling around to get it to "do what you want", it's not necessarily trivial or the same for everyone.
Tell him/her to look for this file https://code.google.com/p/xrnx/source/b ... ctions.lua, override it, and mess around from there.
Using this PHP class I can trigger a note via UDP like so:
$c = new OSCClient();
$c->set_destination("127.0.0.1", 8000);
$m = new OSCMessage("/renoise/trigger/note_on", array(
-1, 0, 100, 60
$c->send($m);
If i send garbage, it of course won't play:
-1, 5000, 100, 60
$c->send($m);
The above doesn't work because there is no track 5000.
Regards,
-1, 0, 100, 60
$c->send($m);
-1, 5000, 100, 60
$c->send($m);
Regards,
ErotiCore SteNch
i think i already knows the answer to this one but here goes
i HAVE to use OSC to control renoise from usine right i cant use midi ???
i can't help you with PHP, Usine don't use php to send OSC,
and it's certainly better if it's you who post on the Renoise forum..?
about midi , yes with a virtual midi drivers no problems and more easy for you to send informations to renoise..?
ErotiCore SteNch
the above message IS from the renoise forumnay-seven wrote:i can't help you with PHP, Usine don't use php to send OSC,
http://www.renoise.com/board/index.php? ... -problems/
thanks for your help,will try to mess with different stuff
