Enable Audio Engine When Usine Loads
CleverConQueso
Does anyone know if it's possible to have the audio engine start automatically when Usine launches rather than requiring that the user press the space bar or click 'off'? I am looking for a patch to load automatically and start playing when the machine boots up without human intervention.
-CCQ-
-CCQ-
This will do what you need. Put this in a master section patch.
or , if you don't want use the master section, you can add a always calculated module and use this patch in any patch
CleverConQueso
Thanks. team. Those work great. Funny how the second before I need something, there's a patch for it.
I've got my wkp to turn on and go to IB mode automatically, but I still always have to enable fullscreen mode myself. There doesn't look to be a dashbord input for that.....
Is there a way to do this by IML??
not sure for the iml, gone to check
but there's the midi learn option which works fine, here i've use a midi learn of CC 23 on the full screen button:
Ahhh--that'll do!
Users browsing this forum: No registered users and 35 guests
