Size & Position of UI elements ?
protofuse
Unread post by protofuse » 03 Aug 2011, 21:44
Hi mates,
can we resize the UI elements without using the mouse ..?
I mean, can we change the size & the position by using some constant defined somewhere in the patch, in an hidden menu related to the UI element or even by scripting ?
can we align UI elements easily ?
best,
Unread post by nay-seven » 03 Aug 2011, 22:28
One day all UI parameters will be accessible as the controls ones, but it's not implemented yet
protofuse
Unread post by protofuse » 04 Aug 2011, 09:47
got it!
(btw,it was more a question on "how can I do better than I'm doing ?" than a suggestion.. of course, actually, it is TOTALLY ok!)
Unread post by nay-seven » 04 Aug 2011, 10:06
no problem,
about align layouts, there's also the grid function in the layout window, setting the good size and click in the background can help
Unread post by 23fx23 » 04 Aug 2011, 10:31
There are two iml commands u can access via script or sendmsg module:
Set_ctrl_pos and set_ctrl_size.
protofuse
Unread post by protofuse » 04 Aug 2011, 12:05
23fx23 wrote:There are two iml commands u can access via script or sendmsg module:
thanks a lot :)
didn't explore yet IML messages
but I got it, using analogy with other patching system in my head :/
Users browsing this forum: Google [Bot] and 89 guests
