How to arrange control elemens stay in front of VST
Be4Be2
Unread post by Be4Be2 » 02 Aug 2011, 20:49
Hello!
I am trying to add multi touch ability to a VST PLUGIN by mapping its controls to Usine faders and buttons(midi).
I put the plugin in "control panel" (not standalone window). Now i try to cover its interface by panels and buttons while leaving some information areas uncovered. It works fine till program restart. All buttons and faders are now hidden by vst interface.
QUESTION: How to make elements be ALWAYS on top?
Unread post by nay-seven » 02 Aug 2011, 21:12
there's a new function " stay on top " but don't work with VST interface , senso will confirm but i think it's a Windows issue
Be4Be2
Unread post by Be4Be2 » 03 Aug 2011, 00:25
nay-seven wrote:there's a new function " stay on top " but don't work with VST interface , senso will confirm but i think it's a Windows issue
Thanx for second fast replay!
As i understend this function on new version?
Unread post by nay-seven » 03 Aug 2011, 08:25
no, actually"don't work with VST interface"
works only for Usine interface objects.
Unread post by bsork » 03 Aug 2011, 10:25
I haven't tried this (and I don't have time to try right now), but maybe it will work if, when initializing the patch, you first set the Usine objects to Invisible, and then set them back to Control Panel.
If this works, you can add it to the patch either with connections or using IML. With connections, I guess you'd need to have a WaitOne or two before turning the objects back on, but with IML messages, I guess you can skip that part.
Unread post by nay-seven » 03 Aug 2011, 11:32
Clever Bsork !
works perfectly :
Be4Be2
Unread post by Be4Be2 » 03 Aug 2011, 12:14
Thanx a lot! I'll try it soon!
