Dear new friends,
may I ask a question which could sound newbie?
ok. I guess I can.
Can we create from scratch UI elements ?
I mean, buttons, sliders, panels etc everything ?
cheers,
About GUI elements design
julien
julienbayle.net
designthmedia.com
soundcloud.com/protofuse
_ _ _ _ _ _ _ _ _ _ _ _ _
Ableton Certified Trainer
julienbayle.net
designthmedia.com
Hello protofuse, glad to see you here
i will let the SDK specialist answer for the code part, on the patch level you can use of course the edit layouts possibilities and also import design created with Knobman for example.
Okay
I guess, we could also use "pure" vector or bitmap graphics too, right?
julien
julienbayle.net
designthmedia.com
julienbayle.net
designthmedia.com
on patch level, jpg and bitmap yes
got it.
(thanks
free version unavailable
I wait for a bit
I'd like to begin to play but I'd buy the maxi/pro version in order to really test deeper.
(thanks
I wait for a bit
julien
julienbayle.net
designthmedia.com
julienbayle.net
designthmedia.com
Users browsing this forum: No registered users and 27 guests
