Concatenate bitmaps
ethnix73
Unread post by ethnix73 » 05 Mar 2011, 13:17
A simple question:
Is there anyway to concatenate bitmaps?
For example, four wavdisplay wich would be in the matrix module using the bitmap in inlet.....
Seb.Dub
Unread post by nay-seven » 05 Mar 2011, 14:04
here is a try , but you'll have only one wavedisplay at final which cumulate the different ones, i suppose you want to see the 4 distinct ones..?
you can also chain the wavedisplay with same result
ethnix73
Unread post by ethnix73 » 06 Mar 2011, 12:34
Thanks nay-seven,
But, yes, i would like to see the 4 distinct ones. Perhaps, it's not possible...
Seb.Dub
Unread post by 23fx23 » 06 Mar 2011, 13:53
i don't think it's possible yet.
