Angle and distance in an XY Pad
gthibert
Unread post by gthibert » 01 Mar 2011, 00:09
It's more a math question than an patching question, but here's the idea.
To control Ambisonic plugins, I want to get the angle (0 to 360) and the distance (0 to 1) of a ball in an XY pad, relative to the center.
Examples :
Ball at the middle = angle of 0, distance of 0.
Ball at upper left corner = angle of 135, distance of 1.
Ball at bottom right corner = angle of 315, distance of 1.
Anyone have an idea ?
- Guillaume
Guillaume Thibert
www.cemproduction.com
Unread post by nay-seven » 01 Mar 2011, 08:30
about the distance you can find an example in the addon named Morphusine
the match formula is
distance = /¯ [ (X1-X2)² + (Y1-Y2)²]
i will look if if i find about angle
gthibert
Unread post by gthibert » 01 Mar 2011, 15:09
Thanks !
Guillaume Thibert
gthibert
Unread post by gthibert » 02 Mar 2011, 19:44
I've found a solution. I don't totaly understand the maths (i've found the formula on the web), but it works.
Here is the script :
Code: Select all
var xIn : Tparameter;
var yIn : Tparameter;
var angleOut: Tparameter;
var distanceOut: Tparameter;
procedure init;
begin
	xIn := CreateParam('x',ptDataField); SetIsOutput(xIn,false);
	yIn := CreateParam('y',ptDataField); SetIsOutput(yIn,false);
	angleOut := CreateParam('angle', ptDataField ); setIsInput(angleOut,false);
	distanceOut := CreateParam('distance', ptDataField ); setIsInput(distanceOut,false);
end;
function sgn (a : real) : real;
begin
	if a < 0  then  sgn &#58;= -1
		else  sgn &#58;=  1;
end;
function atan2 &#40;y, x &#58; real&#41; &#58; real;
begin
	if x > 0       then  atan2 &#58;= arctan &#40;y/x&#41;
	else if x < 0  then  atan2 &#58;= arctan &#40;y/x&#41; + pi
	else                 atan2 &#58;= pi/2 * sgn &#40;y&#41;;
end;
Procedure Callback&#40;n&#58;integer&#41;;
var x&#58;single;
var y&#58;single;
var angle&#58;single;
var distance&#58;single;
begin
	if &#40;n=xIn&#41; or &#40;n=yIn&#41; then begin
		x &#58;= &#40;getValue&#40;xIn&#41; - 0.5&#41;;
		y &#58;= &#40;abs&#40;getValue&#40;yIn&#41; - 1&#41; - 0.5&#41;;
		//angle
		angle &#58;= atan2&#40;x,y&#41; * 180 / pi;
		if angle < 0 then angle&#58;= angle + 360;
		setValue&#40;angleOut, round&#40;angle&#41;&#41;;
		//distance
		distance &#58;= sqrt&#40;x*x + y*y&#41;;
		setValue &#40;distanceOut, distance&#41;;
	end;
end;
Guillaume Thibert
gthibert
Unread post by gthibert » 02 Mar 2011, 20:08
Does anyone knows how I can reverse those formulas ?
Getting X-Y from angle and distance ?
Guillaume
Guillaume Thibert
Unread post by nay-seven » 02 Mar 2011, 20:09
cool, but how do you use it..?
don't have anything from the out of the script...
gthibert
Unread post by gthibert » 02 Mar 2011, 20:18
If you connect the pos-X, pos-Y out of a XY Pad to the in of the script, it should work.
It works on my side...
Guillaume Thibert
Unread post by nay-seven » 02 Mar 2011, 20:42
strange , i see something in , nothing out...
Unread post by senso » 02 Mar 2011, 23:59
the script seems to be perfect!
to reverse the formula:
x = distance*cos(angle)
y = distance*sin(angle)
Unread post by nay-seven » 03 Mar 2011, 00:42
ok, forget it , was experimenting too much thing in the same time ..
works fine
gthibert
Unread post by gthibert » 03 Mar 2011, 01:59
Thanks Senso,
It works !
The only thing, is that if you want to control angle with a value from 0 to 360 the formula should be :
x = distance * cos(angle/360*pi*2)
y = distance * sin(angle/360*pi*2)
Guillaume Thibert
Users browsing this forum: No registered users and 138 guests
