drag and drop samples to VST from browser?
soundmind
Unread post by soundmind » 09 Nov 2010, 05:15
I am trying to drag samples from usines browser onto shortcircuit sampler but it doesn't work even though the plugin supports this behavior. It works when tested in reaper using the media explorer. Is there anything I should know?
Unread post by nay-seven » 09 Nov 2010, 07:13
right, works from a windows window, not from the window browser
must be a question for senso..
soundmind
Unread post by soundmind » 09 Nov 2010, 07:33
yes exactly. And if using the windows browser then there is no sample preview before loading unless you open the file in an audio player which i'm not sure will work because usine is using the soundcard?. I hope the boss has plans for this?
Unread post by senso » 09 Nov 2010, 09:04
is it humor?
Each DAW as it own browser management.
Can you drop a file from FLStudio to Ableton Live?
Can you drop a wave file from Live browser to Windows Explorer or NIBattery file list?
etc...
Shortcircuit doesn't accept Usine's browser files. That's all! And will never! :)
soundmind
Unread post by soundmind » 09 Nov 2010, 10:04
If it can't/won't be done then that is fair enough. For anyone who is interested I've found a good solution. It is called tackybrowser by modulr (subliminal.org). It is a VST plugin that acts as a browser which lets you preview samples and drag and drop to VST and works perfectly in usine. http://www.gersic.com/plugins/hosted/su ... -v1.00.zip
Users browsing this forum: No registered users and 101 guests
