I'm facing a problem with the matrix and the exclu mode patch.
When using the matrix in this mode, the preset manager does not seem to work.
Am i doing something wrong, or if not does somebody has got a workaround?
matrix exclu mode and preset manager
talking about cells on / off , you're right..
works time to time 1/10 , maybe martin can answer this..
sorry no workaround right now..
just found : add a pass if change between the out of the sub-patch MX_exclu_mode to the in of the matrix, seems working...
edit :hmm, not really well , you have to click twice sometimes...sorry
Thanks for your answer nay-seven.
But in my patch, this workaround does not work. Maybe because i set the cells from an external controller...So it seems that the preset manager is only able to store the last set cell.
Seb.Dub
I have perhaps found a workaround by storing the value of the matrix in an array, and stopping the flow from the matrix to the array when using the preset manager...
Seb.Dub
cool, gone to test this later
Users browsing this forum: No registered users and 123 guests
