Buton to play sample
Unread post by cmodica » 22 Sep 2010, 17:30
I'd like to build a patch with 3 buton and each of them play a different sample.
I have one sampler stereo with 3 sound file.
I would like to have 3 buton, one for each file.
The buton1 select the first sound file in the list (number 0) and play it
The buton2 select the second sound file in the list (number 1) and play it
The Buton3 select the third sound file in the list (number 2) and play it
It seems to be very simple but i can't find a solution. I try without succes with Math Module, from 0 to 1, from 1 to 0 .... :mad:
I need a little help.
headphoner
Unread post by headphoner » 22 Sep 2010, 17:55
did you tried the multiple variable module ?
put an "has changed" to the out it will send 1 to the play sampler
Works fine
Unread post by nay-seven » 22 Sep 2010, 18:26
yep, something like this :
( this is for play button mode , if you use the loop mode , you can delete the has change module)
Unread post by cmodica » 22 Sep 2010, 18:48
YES !!! Great !
It's work fine. Exactelly what i need !
I had to take a look at the manual to know all the module ....
Thank you very much.:D
Unread post by cmodica » 22 Sep 2010, 19:01
Even in Play mode i don' need a 'has change''.
I use a ''Wait one cycle'' to be sure that the sound file is selected before playing.
It works fine.
Unread post by 23fx23 » 22 Sep 2010, 19:05
Btwn with new V5 buttons, you can simplify and get rid of multivar, simply enter the sample nb as button on value,
enabling "null evt if off'. however if sample nb is 0 (have to put -1 has off value), slighty lower CPU i think
Unread post by nay-seven » 22 Sep 2010, 20:03
right !
often forget that button have same features than switches now !
1 point for you ;-)
Unread post by cmodica » 23 Sep 2010, 09:53
Wahou !! Beautiful !!!
i forgot the new features of the Buton.
I will try it immediatly.
Thanks.
Unread post by cmodica » 23 Sep 2010, 13:49
I have a new question about this patch.
The buton1 play sampl1. But if i want to re-play the sample 1 before play an other one i can't becuse there is no change in the ''has change'' module.
How can ido that ?
i could just ad a play buton directly connected to the play of the sampler, but i want to remote the 3 butons with a control surface ...
thanks
Unread post by nay-seven » 23 Sep 2010, 14:10
this can do the job :
( same system of course for on/off value )
oops, forget it .........don't see about the midi learn...
Unread post by nay-seven » 23 Sep 2010, 14:30
so back to old methods...
my first patch works whith midi learn...
Users browsing this forum: Google [Bot] and 18 guests
