audible click with grain sampler?
soundmind
Unread post by soundmind » 26 Aug 2010, 02:31
Im not sure where to post this because I dont know if its a bug or not but when playing single sample "hits" with the grain sampler in button mode there is an audible click at the end of the sample playback. Anyone else have this experience?
Unread post by nay-seven » 26 Aug 2010, 09:14
so, several question..
have you this problem with several samples or only this one..?
have you try to activate zero cross mode in the grain sampler..?
have you open this sample in an editor to check it end..?
same problem with the sample player..?
soundmind
Unread post by soundmind » 26 Aug 2010, 19:30
yes this happens with several samples and zero cross has no effect also. Also this started happening with the new usine update. basically Im using a seq switches module to trigger the play button of a grain sampler which plays single drum shots to the samples end but when it reaches the end it clicks rather loudly. before the update the same exact samples did not produce this effect. I will check to see if it happens with the sample player. thanks
Unread post by senso » 26 Aug 2010, 19:55
confirmed, will be solved soon+++
soundmind
Unread post by soundmind » 26 Aug 2010, 20:01
great! thanks a lot.
Unread post by senso » 26 Aug 2010, 20:13
this bug is fixed.
next release.
Users browsing this forum: Google [Bot] and 22 guests
