OSC ?
multiphone
are ya sure the good adress is entered in module? check also port in osc setup.
multiphone
hello 23 fx,
Thaks for reaction.
The right adress in the module ? If i have 0.0.0.0. or 169.254.137.125 is the same : No entry...
In port in the OSC Setup is...???
Thanks in advance.
Thaks for reaction.
Thanks in advance.
hello hervé
the adress for osc is what you see in the console , by default , it's Usine , depending from what device you send OSC
here an example :
about the port , it's the same problem: your device ( for example an ipod )must send OSC on the same port than Usine ( by default in the osc setup window = 8000
here an example :
multiphone
Hello Nay Thanks to take time...
But as allway i feel i'm a big nozzle
So,
The info get in the console from 169.254.137.220:/accxyz (fff)
so i type 169.254.137.220 and remplace /usine/ ???
i'm lost in OSC
So,
i'm lost in OSC
we all have begin like this with Osc , don't worry
first ,don't worry with ip and try to just to replace /usine/ by
/accxyz/
must be enough
/accxyz/
must be enough
multiphone
rrrrr....
no effect !
Strange !?
no effect !
Strange !?
mmm, my fault try also without the last /
if not , can you try to make a screen capture of you osc console
here mine ( i've disable osc here to stop message,
click on one message to see details in the lower window and be careful you don't have adress like
/2/accxyz
or something like this...
/2/accxyz
multiphone
Here it is...
I think after that we need to write a short wiki for OSC basic problem
the valid osc address is
senso+++
Code: Select all
/accxyzOlivier Sens
multiphone
OMG !
Thanks Senso !! And Nay for your advices.
I dont know wath apend but it works... i enderstand the valid osc adress now.
Thanks a lot.
Thanks a lot.
cool+
