audible click with grain sampler?
so, several question..
have you this problem with several samples or only this one..?
have you try to activate zero cross mode in the grain sampler..?
have you open this sample in an editor to check it end..?
same problem with the sample player..?
yes this happens with several samples and zero cross has no effect also. Also this started happening with the new usine update. basically Im using a seq switches module to trigger the play button of a grain sampler which plays single drum shots to the samples end but when it reaches the end it clicks rather loudly. before the update the same exact samples did not produce this effect. I will check to see if it happens with the sample player. thanks
confirmed, will be solved soon+++
this bug is fixed.
next release.
next release.
