problem with midi bus
oxyredox
Unread post by oxyredox » 20 Jul 2010, 00:18
I'd like to mention a problem I've encountered several times.
I have several sets of two patches on different tracks that need to communicate through a MIDI bus. I use "patch loaders" contained in a third patch to load each pair. And most of the times, they don't communicate, so I have to reload each patch (the one that sends, and the one that receives) to make it works and get the MIDI flowing.
Is there a solution or an explanation (apart from making one patch instead of two...) ?
Unread post by nay-seven » 20 Jul 2010, 09:20
not sure to understand but have you check the target function of the sending bus ( global, tracks only...)
if you use global and have the same name for different buses , could have some conflict..?
oxyredox
Unread post by oxyredox » 20 Jul 2010, 16:06
I think you understand !
For each bus name there's only one send and one receive, and of course they're set to global. The problem is I have to reload one or two of the patches to have them working together, without modifying anything in the patches... Sometimes I have to delete the receive module and recreate another with the same bus name...
I was wondering if the order in which the send and the receive are created was important... Otherwise it just looks like a bug or my laptop is a wreck !
by the way I'm using version 5bet7
Unread post by nay-seven » 20 Jul 2010, 16:54
ok , so maybe updating Usine could be a good idea...:)
btw I've test one button to 2 different load patch module , one who send , one who receive..no problems here apparently..?
any other factor..?
gurulogic
Unread post by gurulogic » 20 Jul 2010, 19:08
Update!!! Why are you still using an old beta version anyways?
Users browsing this forum: Google [Bot] and 22 guests
