Posted: 10 Apr 2008, 12:26
Hey!
I was wondering if there was a way to automate the conductor without having to know the SMPTE positon? I was hoping to do this with a piano roll on a spare track containing the midi notes for switching parts, sent out of Maple Midi cable, but I can't get it to work (probably my fault). Would it be possible to add a column to the normal conductor where you specify the number of bars or cycles alongside the SMPTE position? Alternatively is there an way easy way to implement this feature as it is?
Thanks!!
Thanks!!
