in the array display, there is parameters for a cursor, wich is great, but couldn't find any input to actually move the cursor.
Also it would be fun to be able to set the steps colour individually with a color array.
array display
array display
the answer is : use the step sequencer !
You mean you feed a step sequencer with your Array and move your cursor where you want to ?
"Also it would be fun to be able to set the steps colour individually with a color array." +1
I think I already asked for that, it would be really more efficient to quickly read an array and find the value you're looking at ...
It's just for visualisation purpose. otherwise I'll use "get element value"grego mondo wrote: ↑27 Jun 2025, 17:14You mean you feed a step sequencer with your Array and move your cursor where you want to ?
As Senso explained to me, colors are a "settings" that are refreshed at refreshed rate (usually every 25ms) and not audiorate. Making them array compatible will take too much CPU time. maybe we could hack a matrix for individual color cells ?grego mondo wrote: ↑27 Jun 2025, 17:14"Also it would be fun to be able to set the steps colour individually with a color array." +1
See you soon !
