Cloud sampler improvment
Unread post by oli_lab » 30 Apr 2025, 17:09
I'm currently reading this article on granular synthesis, quite exhaustive !
I'm trying to use this knowledge to implement new patches for Usine (an add-on is commng)
The actual cloud sampler is quite complete as well.
I wonder if it would be interesting to have the option to have the pitch to follow continuously a pitch-bend control input.
for now, the pitch is set as the grain is created and stays that way until another grain is created with another pitch, witch is great, but to add the possibility to bend the grains while playing would add another fun-ctionality !
Not exactly the "Glisson" concept (which is a grain with a pitch enveloppe) but probably it is too much a burden to add to the curent cloud module.
https://artesonoro.net/articulos/The%20 ... 20GiST.pdf
Curriculum
Unread post by Curriculum » 22 May 2025, 10:14
Hi
The idea of being able to modify the pitch of a grain would be very interesting as long as it has sufficient duration.
I'm curious to try the add-on.
thanks
Unread post by grego mondo » 22 May 2025, 11:05
+1
