Wishing list
Wishing list
Unread post by Gilsornette » 15 Feb 2025, 16:39
I regularly take notes of things that I would like to see modified or implemented in Usine. Here's my wishing list:-)
Please don't hesitate to tell me if ot's not a good idea to post so much demands in one topic...
- devices menu displays the device group name
- possibility to move the devices in the devices menu ; to sort them as needed, and also because Usine chooses by default the 1st device as output
- being able to drag and drop a switch into the grid and have access to on and off values (as fader in non-curve mode)
- being able to move a section in the grid by «affecting» the new location, rather than by sliding (complicated when long grid)
- in patch settings , having a «reduce patch» input; there are two minimize inouts but no reduce ("-" in header)
- being able to open several patches windows simultaneously (convenient for comparing, searching ...) > probably very complicated but we never know...
- an option to load samples in midi sampler in loop mode by default
- in audio samplers modules, a trigger when it comes to end, not only on restart; sometimes more useful than when restart > to change zone markers for example (when you have to trigger somthing before the loop recovery)
- already asked , but (for me) indispensable : the possibility to save presets lists
- an option to make the intensity of the LEDs proportional to the signal received
- a global option «ignore show rack/patch when active on grid»; sometimes useful to be able to observe a rack/patch by "scrolling" the grid without having the other ones shown
- mixer: an option to have only active racks visibles
- it'd be very useful if the "record on click" option also works with midi/osc remotes
- having an output on objects to be able to display names of drag and drop binds and not only buses
Thank you very much
Unread post by senso » 17 Apr 2025, 16:51
interesting suggestions,
I'll study them carefully.
Unread post by cmodica » 18 Apr 2025, 09:14
Very interesting wishes.
Unread post by senso » 24 Apr 2025, 11:59
in the next release major release
OK
OK
OK
not sure...
The "is playing" output does a good job ?
not sure it's possible...
A new "audio-vu-meter-led" module will be created
OK
hard implementation because it is not easy to know when a MIDI flow has stopped... unless wait few seconds
OK
Unread post by rlgsbt » 24 Apr 2025, 17:32
great !
Unread post by Gilsornette » 25 Apr 2025, 08:10
Thank you very much!!!
Unread post by cmodica » 25 Apr 2025, 08:59
8)
