select and copy object path
Unread post by woodslanding » 19 Nov 2024, 19:54
It's great that I can see the object path in the inspector for a control, thanks!
But it is frustrating that I can't see the WHOLE global path, and can't select or copy it, to use or to look at in a text editor....
EDIT: That said, usine Objects are GREAT!!!!
