Hollyhock with Capture visualizer
Georg Vogt
Unread post by Georg Vogt » 28 Apr 2020, 19:29
Hi there,
I am new to HH4 and bought the software some days ago. I hope HH4 can be connected to Capture 2020 visualizer because I believe this combination would allow for the creation of beautiful lighting design.
When I first started HH4 it actually connected to Capture, via loopback adapter and I was very happy. Unfortunately I am not able to get the same anymore and honestly don´t know why.
--- is there a tutorial that shows how to get HH4 working with Capture on the same computer?
--- could someone help with this?
Capture is used with many lighting consoles and they provide something called Capture component that allows a close integration between console and visualizer. I would very much appreciate if it were possible to have this integration. It facilitates the patching a lot and Capture produces very accurate visualization.
Thank a lot for your interest
George
Georg Vogt
Unread post by Georg Vogt » 02 May 2020, 01:08
I managed.
Unread post by senso » 26 May 2020, 10:34
hi,
sorry to answer lately.
Capture works well with Usine, we use everydays it at the office.
The best way is to activate the 'broadcast' option in the plot, then Capture will be able to receive ArtnetDMX on the same computer.
senso++++
