If you drag a combo box input pin and create a list box the items will be taken from the pin you dragged.
It would be useful if a list box had a "set from target" trigger, that would update the list from the target.
One example, if you have a listbox connected to the preset manager "current" pin, and create a new preset you have to delete and re-drag the listbox to get the updated list items.
To update the list automatically would waste processing power, but a trigger pin to do this would be very useful.
For target pins other than type combobox, the option would do nothing.
Simon.
list box update from target
- x.iso
- senso
humm...not so easy but I'll try to find something
