Lock Patch Selection / Lock Rack Selection
lytz1
Unread post by lytz1 » 08 Dec 2018, 18:33
Hey there,
Because we have 'if patch is selected' and 'if rack is selected'
for midi/key bindings, it would be cool to have a (temporary?) lock function.
Problem: When you click on a control in a selected patch (or in a selected rack)
the rack/patch gets deselected and the binds don't work anymore.
So we have to select the patch/rack again.
Maybe there is another solution for this, but my idea was some kind of "Selection Lock"
so that the focus for the binds doesn't get lost when adjusting a parameter inside the selected patch.
(It's a parameter of the selected patch anyways, so the patch shouldn't lose focus, right?)
Best,
tL.
Unread post by senso » 09 Jan 2019, 08:25
It's a good suggestion but as you can see I'm not a great fan of adding settings options again and again.
I'll think about it and try to find a soluce.
