Page 1 of 1
Posted: 11 May 2018, 23:15
by joffo78
I suppose it's not very easy.
But it would be fantastic if sampler recording could follow the play position, the pitch, the speed and the loop lengh.
Actually, when i'm in overdub mode, if i make a record when i'm in reverse, the new input isn't recorded à the position where the sampler is like a traditional looper.
i suppose that it's a problem to the core of the sampler. So peharps a sampler module dedicated to overddubing would be the solution ( with undo please !!!).
So for my project, i need also a reverse, pitch (eventually stretching) , marker to slicing and of course overdubbing and circular buffer mode.
I notice to when i use sampler in overddubing, it make a lot of click.
I know that this question is not very easy to resolve, and i wonder how the hardware loopers avoid it .
thanks a lot.
JF
Posted: 13 May 2018, 11:17
by senso
good suggestions.
Ill try to find solutions. probably in the next major release.
Posted: 13 May 2018, 12:46
by joffo78
Fabulous !
Posted: 13 May 2018, 17:16
by oli_lab
did you try the "sampler Elite" ? :cool:
Posted: 13 May 2018, 22:19
by joffo78
No. what is it ?
Posted: 13 May 2018, 22:26
by joffo78
oli_lab wrote:did you try the "sampler Elite" ? :cool:
I found it.
Sorry but i don't understand anything about it.
Posted: 14 May 2018, 11:26
by oli_lab
it's a sampler for the "elite" ;)
very modular and highly tweakable, needs extra patching to make it works to one's taste.
note that if end marker is before start marker, it goes backward
there is a cross fade fonction as well
it can read up to 64 loops of the same sample.
in that case you can choose play mode to get continuous loops or one shot loops that end either at end of shortest one or longuest one.
you can only record samples live, no read from file yet.
File uploaded: http://www.sensomusic.org/forums/upload ... 20mono.pat
Have fun !
Posted: 14 May 2018, 11:51
by joffo78
I don't understand what are the avantages between a traditionnal usine sampler.
Posted: 14 May 2018, 12:11
by oli_lab
joffo78 wrote:I don't understand what are the avantages between a traditionnal usine sampler.
as I said it is different :
up to 64 loops from the same sample will reduce RAM use
minimal blocksize : when end and start marker are very close you can choose from glitchy to smooth...
Xfade...lofi or interpolated quality...
File uploaded: http://www.sensomusic.org/forums/upload ... 0multi.pat
Posted: 14 May 2018, 12:16
by joffo78
It looks cool but i don't understand how that it works. Maybe i'm not the elite !
Posted: 14 May 2018, 21:11
by oli_lab
now, that I read again your post, you maybe right :
there is a record pos output on my module, but I'm not sure you'll be able to patch what you need !
