Option to disable/bypass audio threads on video player.
Blaakk
Unread post by Blaakk » 02 May 2018, 19:39
I'm trying to listen to some music while video patching. Audio is crackling like mad even at low CPU rates, both outside of Usine, and it's worse inside of Usine. When outside (VLC), the audio goes mental when moving the video position slider.
Or maybe some kinda bug (I can move the 'current audio buffer' slider in the module settings, which I don't think is right). Sometimes audio buffer shows activity, sometimes not.
Cheers!
Unread post by senso » 13 May 2018, 11:11
1)The video engine can take a lot of cpu so it can interfere with other running software's. Nothing we can do except buy a huge computer.
2) the 'current audio buffer' shouldn't be moved. Will be corrected in the 171. Its "activity" depends on the codec used. It can change or not.
