Sequence Lines/Steps/Etc - One Shot
sephult
Unread post by sephult » 12 Nov 2017, 01:32
I think the Sequence Lines/Steps, etc...
Should also have an option for One-Shot.
At the moment I'd like to Trigger and ignore incoming until the sequence has finished.
I know I could find a workaround, but even then there is not a specific node for "resetting" like on a sampler, etc.
I think these "Button" modes should have a node that enables/disables one-shot.
-s
Unread post by senso » 29 Dec 2017, 18:57
I think it's a little bit specific to implement this feature. The workaround is very easy?
damstraversaz
Unread post by damstraversaz » 29 Dec 2017, 19:26
It could be useful !
