multiple Inputs logicals
Unread post by 23fx23 » 25 Mar 2017, 02:32
Ie on a AND, OR ect logical modules mainly, have the possibility to define 4 input instead of chaining several, one other soft i use in 3D works like this, find can be handy sometimes
and more clear/less webby.
here it can dynamically update, mean if there where 2 wired input, and decide later for a third condition, man can extend to 3 or more keeping actual wiring done intact and plug the new condition.
prob hard in usine as multi Io are 'traditionally' done at drop time but who knows maybe some wizard thing is possible :p ..just a reflexion
Unread post by oli_lab » 25 Mar 2017, 05:42
on some software I use for industrial purpose, the AND module is 4 inputs and each input is on logical 1 by default, so if you use only 2 inputs the other ones being on, the AND gate still works OK (a.b.1.1 = a.b)
Unread post by 23fx23 » 25 Mar 2017, 18:08
Yeah nice, make sense. maybe could be there internaly but not visibles, and num param set visible only wanted nuber pins
