keyboard shortcuts
Unread post by sm_jamieson » 09 Dec 2016, 01:54
Most of the keyboard shortcuts can be modified by setting up a new key learn to change the setting.
There is one that cannot - the up and down arrow selecting racks. There is no button to do a midi learn on.
There may be other global keyboard shortcuts like this.
Please can we have a way to disable any global keyboard shortcuts that cannot be changed with a midi learn.
I wish to use keyboard input in my patches, and these just get in the way.
Simon.
Unread post by senso » 21 Dec 2016, 17:12
It will be possible in HH3
with a new "learns" buttons which shows all the learns. Then you can disable the cursor keys learns.
