sdk Automation: specify value type
Unread post by 23fx23 » 20 Oct 2016, 16:20
when we record a boolean value type ie button, swich status ect, automation on playback use linear interpolation by default
so don't reflect what was supposed to be wanted on playback.
can be possible to filter back in the code but events might be missed by checking if =0 or if =1 to recreate a bool from curved playback
if adding a magin for test then can trigger earlier or later.dk if see what i mean.not drastic but
in case was possible a way to pass info on record of type of data for X,Y,Z separately would be cool, so that curves
on playback are set same way (aka "value curve type" on automations settings)
Unread post by senso » 09 Nov 2016, 22:28
I'll check this. It should be possible.
