In some cases params on tabs don't always refresh reflecting pointers when their value changed
for ex i make a bool swich setting 'apply color corect' that i dlike virtally acts as a button, if pressed trigging a colors changes of a set of displayed colors in tab then goes back to 0.
in onsettinghaschange i set back this switch pointer to false so act as a button, trigg the color correct code and that works,
but visually the tab doesn't reflect color changed or not always the swich status that went to false. have to go to another tab and come back to tab to see change.
not big deal, just in case a not too complex way to force a refresh of params in tabs from code would be possible could be nice.
thougt a tab id or tag info eventually could be cool too :p and per tab presets would be insane but think already spoke about that^^
sdk module Tabs refresh, tab id info
- senso
I'll check that but the best way is to ask for a repaint after the modification.
The settings panel do not verify that value have changed (it takes a too long time).
So you have to repaint it manually.
yes i already use manual repaint on module sometimes, but this is only possible for 'real' parameters out of module calling id , think yes best would be to be able to manually request a same kind of repaint for the params located in a tab, i suppose calling by it's name
