Posted: 23 Sep 2016, 13:26
Hello Senso!
TParameter Initialization Parameters "setIsInput" & "setIsOutput", are very confusing and not intuitive.
To set only an input you have to do "setIsOutput(io,false);"
To set only an output you have to do "setIsInput(io.false);"
If you do the logical it doesn't work right ex... "setIsInput(io,true);" does not give you only an input.
This ends up creating both an input and output.
The same goes for setting output as true.
-s
-s
