Number of Module Node
sephult
Unread post by sephult » 19 Aug 2016, 02:22
It would be nifty to have a way to display the number associated with each node of a module in the patch edit view. This would help quickly identify so when scripting or writing IML it is easy to reference.
A hover over the node for a medium time could display the number?
-s
Unread post by senso » 09 Sep 2016, 16:05
the script need a deep refresh. But dont forget that you can also create links by in/ou name, not only numbers. it can be easier?
CREATE_LINK FADERMODULE "gain" VOLUMEMODULE "gain"
sephult
Unread post by sephult » 09 Sep 2016, 23:15
Thanks for the input Senso, always appreciated.
I didn't think about using the name references, I will have to use them better in practice.
-s
