The auotmap program does not work with Usine.
It does work with Ableton, Sonar, Bitwig, ... many others.
It may have something to do with "ReWire" compatibility?
Novation Automap
dmitriyc
Novation Automap has been a flaky tool in my toolbox for quite some time. I've followed it recently and the only thing I can even recommend that is anything worth of note is an OSC-based third party plugin for Lightroom. Look up Device Templates for Paddy.
Perhaps I'll dust mine off and see if there is any way I can make it sing in Usine...
- nay-seven
I use an old Nocturn controller with automap and Usine on Mac, works fine here ?
