auto rewiring of recompiled module or script
Unread post by sm_jamieson » 30 Dec 2015, 18:53
When I recompile an SDK module where some parameters have been renumbered, and reload a workspace or patch that uses it, the links to the renumbered parameters are correctly moved, i.e. they use the names rather than the parameter numbers.
When you recompile a fastscript with renumbered parameters, the links get broken even if the names have not changed.
It would be very useful it a recompiled script could behave like a recompiled SDK module, and preserve the links to renumbered parameters.
Simon.
Unread post by senso » 07 Jan 2016, 21:02
not so easy to do better in the general case!
I'll take a look.
senso+++
