I need sometimes to use the waveplayer to play soundfile (for exemple interview). But i don't need necessary to play all files one after one.
I think it could be interresting to have a select wave file possibility, a next and previous and a play just the selected file. Like in the sampler module with the synchro buttom.
So it is necessary to a a midilearn on this command to use an external control device ....
Of course i can use a sampler !
Have a nice day
By
Wave player
- senso
thanks for feedbacks
Yes, the wave play is very simple. It has been designed to replace an audio input to test patches with the lowest CPU, because it's always running backward in Usine.
If you need more stuffs, I advise you to create a new patch with a sampler and any other commands you want. Then put it on a track (for example at the end track 9 or any).
I think it's a better solution?
- cmodica
OK that is what i have done. You sure right, it could be the better solution.
Thank you
Thank you
