'up' & 'dwn' button in sampler file list
Antonin
Unread post by Antonin » 07 Oct 2015, 13:38
Hi everybody,
the buttons to move up ou down files in the list of the sampler doesn't
change cursor position, therefor it's really difficult to move a file several
lines up or down...
(you need to reset the cursor position after each file jump)
not killing me tho -)
(Usine 2.0 079 / osx.8.5)
Unread post by senso » 10 Oct 2015, 11:52
actually, the selector doesn't change but you can move it several lines up/dwn by pressing several times the buttons.
anyway, will be implemented in the next major release.
Users browsing this forum: No registered users and 25 guests
