module for built in preset managers
La Tenaille
Unread post by La Tenaille » 12 Jul 2015, 10:13
I'd love to control built in PM from patches :)
drakh
Unread post by drakh » 13 Jul 2015, 11:27
just add PM module to patch, and then connect to it some buttons/switches it's easy ;)
La Tenaille
Unread post by La Tenaille » 14 Jul 2015, 08:41
you're right. It's just a pity having these convenient built-in PM, and not using it.
Unread post by senso » 14 Jul 2015, 17:13
Since the 076 the PM module has been improved and can be controlled more easily in patches.
