poly workspace ?
La Tenaille
Unread post by La Tenaille » 04 Jun 2015, 13:58
Looking for a way to manage tunes and events/presets inside these tunes, I realize I miss one step between the "big" workspace change (every little modification needs to be updated manually from wkp to wkp) and the grid steps.
For now I use the grid to change tune, but it's getting a knightmare managing presets.
So what about a kind of layered workspace : all the workspaces can be updated after modifications, except if you uncheck "once in poly wkp" in a rack/patch/module contextual menu ?
I can hear you Olivier, "not easy" ;)
Unread post by senso » 15 Jun 2015, 18:05
the additional wkp is made for that :
put every common racks in the additional wkp and big changes in your main wkp.
I think it can help?
otherwise as you said it's "not easy"... and very complex for 99% of the users?
I'm thinking about alternative solutions. I'll tel you.
