Posted: 14 Feb 2015, 19:09
I would like to thank senso and the team for this beautiful software. However, there is an issue that has not been addressed yet.
In usine v5 when modulating a vst parameter using the parameter array available on each vst, the modulations were instantaneous. Unfortunately in HH this is no longer the case. No matter when using the parameter pins or through the array, parameter updates happen only between a low resolution boundary (bloc?, refresh rate?). I mentioned this a long time ago and the option for instantaneous access to vst parameters was promised but it was never implemented. In its current form, it is impossible to modulate parameters with precise timing resolution. Could this possibly be solved in HH2?
Thank you for your support.
