I was curious if there was ever a plan, or possibly a way to encode the REC out as MP3.
I share works and examples many times as MP3 because of limitations of sending size.
I don't necessarily like to do so, but a must in many cases because raw .wav is too big, or popular sharing does not accept .wav.
Would be nice to be able to do a process to encode, when the recording is stopped...even using free Lame encoders.
I do so now using Sonar, had me thinking if there was anyway to trigger, with the current output filename.
-S
MP3 output encode?
- senso
Unfortunately probably not because the conversion is CPU hungry and not suitable in a realtime context.
The audio in usine is recorded in realtime.
moreover, they are so many audio editors which can do that very easily, so....
