zoom for the patch window
magickz
Unread post by magickz » 27 Aug 2014, 18:18
Sometimes I wish for my old eyes a better readability in the patching window. Maybe it would help to have a zoom function like everywhere else in Usine, and white text color on the rather dark colored modules. Or maybe slightly brighter background colors.
Unread post by woodslanding » 27 Aug 2014, 20:43
I agree about the color scheme--I could use more contrast. And I would use both zoom in AND zoom out in the patching window.
Maybe colors can be edited in color.ini in config? But those settings don't seem to affect everything. For me, when I drag a module from the browser, the patch window background color change makes it absolutely impossible to see the cabling, which is a problem if I want to drop the module on a cable!
Also, I find the transparent cable data list in the patching window very hard to read. I wish I could change the color and transparency of that, I use it all the time, and it's not important to me to able to see what's under it. These may be in color.ini, but it's hard to tell what's what in that window.
La Tenaille
Unread post by La Tenaille » 27 Aug 2014, 21:35
+1
With a 15" full HD laptop screen, elements are very small and patching gets tricky. I'm forced to use an external 24" screen to patch confortably.
Unread post by senso » 14 Sep 2014, 20:06
unfortunately, for performances reason the patch is not "zoomable"
but in HH2 colors of the patch objects will be much more punchy, for a better readability
also the drag color will be smoother
be patient
Jongleur
Unread post by Jongleur » 15 Sep 2014, 07:20
Hello, can we learn more about HH2 and it is for soon. Thank
