Page 1 of 1
Posted: 06 Apr 2014, 05:36
by cephei
Couple of enhancements which I think would be useful:
* Ability to duplicate a line. I can't see a way to copy a grid line at the moment?
* Mute a grid line. So when a grid line is muted it will be skipped. I think this could be useful for trying different arrangement ideas. I don't think there is a way to do this atm.
* Multi select grid lines so I can then use the 'move line up'/ 'move line down' on multiple rows at once.
* Not so much to do with grid line manipulation, but I would love if there was a way that when I pause playback as a grid line is part way through playing, that when I resume play back it just continues playing from its current position, instead of playing back from the start of the grid line. Obviously this would need to be a setting because other times you would want it to restart playing from the beginning of that grid line.
Thanks.
Posted: 06 Apr 2014, 10:04
by senso
many interesting suggestions.
personally, 2) and 4) retain my attention and should be easy to implement.
Posted: 06 Apr 2014, 11:33
by cephei
The reason I think duplicate line could be useful is, I can duplicate the line and then mute it (so it will be skipped), and then try some new ideas on the duplicated line. If I like it I keep that line and delete the original, if not then delete the duplicate and re-enable the original.
At the end of the day, I guess what I am talking about is creating variations of grid lines.
