Page 1 of 1
Posted: 20 Nov 2013, 21:53
by La Tenaille
Could it be possible to have a way to toggle the patching area to fullscreen ?
It would be a real comfort, especially on small screens (my stage laptop for example :)).
Posted: 20 Nov 2013, 22:01
by nay-seven
Have you try to use the floating windows option..?
Posted: 21 Nov 2013, 09:43
by La Tenaille
Yes I tried. I will try again but the screen is getting messy in this mode, the browser jumps to background, and there is no maximise button for the patch window.
Posted: 21 Nov 2013, 11:14
by nay-seven
yes, i know, but i think it's an habit question, once the patch window is maximize , double click to open/close, then CTRL+B and CTRL+I for browser and setting panel...?
Posted: 21 Nov 2013, 13:08
by La Tenaille
I'm giving this mode a second chance ;)
Posted: 22 Nov 2013, 13:29
by drakh
An is there some option to swtich between windows using alt+tab (win7) ? Because in this mode you can not to switch between windows.
As a workaround i am using dexpot and its features...
