drag and drop values
joffo78
Unread post by joffo78 » 19 Aug 2013, 23:44
Hi
it would be very usefull if we can select several controls with the drag and drop mouse fonction.
for example i select 4 differents fader by dragging there. then i can reduce or increase the values with the scroll.
Unread post by senso » 03 Sep 2013, 09:19
not easy to implement in the actual state of Usine.
I'll think about.
