Page 1 of 1
Posted: 11 Aug 2013, 04:17
by ahonoe
When MIDI control is assigned to a switch that is part of a group, it does not turn off the other buttons in the group. It would be helpful if it did.
Thanks.
Posted: 11 Aug 2013, 18:43
by senso
I'm not sure I understand but I works as expected in Hollyhock.
Posted: 14 Aug 2013, 00:00
by ahonoe
Thanks for getting back to me Olivier,
I have assigned 2 switches to group1. If I understand correctly, they should operate like "radio buttons" where if I turn one switch on, the other turns off. This works fine for me.
Next I assign a MIDI controller to each switch. When I trigger one switch via its assigned MIDI control, it does not turn off the other switch.
Maybe I have missed something?
Posted: 14 Aug 2013, 00:16
by nay-seven
I've also tested and works fine with my BCR 2000, even in motorized mode..
Depending of you controller, test different mode ( absolute/relative/toggle) in the remote tab of your switches
Posted: 15 Aug 2013, 01:19
by ahonoe
Ok. I'll try again. (It struck me as strange that this wouldn't work. It's more likely my mistake.)
Thanks.
