stereo buses
La Tenaille
Unread post by La Tenaille » 08 Aug 2013, 15:11
would be nice to send stereo signals. I know it's no more than two mono signals together, but it would avoid L+R names and give a clear vision of the signal paths :)
Unread post by senso » 10 Aug 2013, 11:58
no easy to mix the mono/stereo concept and multi channel.
in usine we took the multi-channel option.
so maybe a multi channel bus in the future?
Unread post by woodslanding » 10 Aug 2013, 19:23
A multiplex option would be nice, not just for audio....
I created mux/demux objects for usine v5, mostly to keep control data synchronized because data from different sends was not arriving simultaneously.
