[Trace] Window for Enable/Disable Trace, Jump To
sephult
Unread post by sephult » 27 Jun 2013, 13:29
I think it would be great to implement a window for the Trace functions.
Ability to have all the traces in a window, enable/disable, comments and to be able to click and jump directly in the patch interface to where it is located.
To me this would simplify debugging patches.
Also would be nice to select an item in the interface and have the ability to enable/disable "Jump to Module" in the patching interface.
-S
Unread post by senso » 10 Aug 2013, 12:00
Yes it could simplify patching process but not so easy to implement.
I keep this idea in mind.
