Page 1 of 1
Posted: 22 Mar 2012, 03:50
by FarfadetFarfelu
I'm using a looper in overdub mode for some guitar looping ala BOSS RC-20 style.
I think i may have noticed an "unwanted feature" : when i FIRST record something in the loop, the sampler passes the signal on its wet output at the same time.
Then when i stop the recording, play the loop, overdub stuff, it plays the looped stuff, and never passes the original signal again, which is good because it should only pass what is looped and not the original sound.
At least it should not behave differently during the first recording, and during the following overdubs.
So basically as it is now, you get a huge volume boost when first recording the loop because the clean signal is passed along through your normal way + through the sampler.
I found a work around with a counter connected to the ouput of "re-starting", to mute the signal when recording the first loop, but i thought i'd still mention that here, because it took me a long time to figure out why i had this weird feedback when starting the sampler on my setup...
Appart from that i'm really having a blast with usine !
Thanks for reading !
