Posted: 06 Aug 2011, 12:24
This suggestion comes from this post
Actually, Load Patch load a patch where you want by replacing totally the previous one (which is normal, useful & efficient!)
I'd like to design reuseable patch (possible already...) and I want to keep this object independant, in specific folders.
Example, I need to code a double LFO.
I patch this one with the intent to use it later.
I patch another synth, using double LFO.
I patch another fx using double LFO.
and ... I decide to improve that OLLLLD double LFO. I improve it.
When I load anything using double LFO, the new one has to be loaded.
This would be amazing.
Best,
Best,
